The Jira Product Discovery - Atlas integration is really nice as is. However, as most things it could benefit from some simple improvements.
One thing I really miss is a dedicated section on the Atlas side where connected JPD Ideas are listed.
In the case of Atlas Projects there could be a special section in the Right panel above the Where is the work tracked? section listing JPD Ideas the Atlas projects contributes to.
Similarly In the case of Atlas Goals there could be a special section in the Right panel below Sub-goals listing Ideas related to that Goal or Sub-goal.
Adding an Atlas project or Atlas Goal to a JPD Idea or vica versa should automatically link the JPD and Atlas entities.
Our company uses both Atlas and Jira Product Discovery. We have the integration enabled in JPD's advanced settings but are unable to fetch the Atlas Goals or Projects fields. We've logged a ticket but are yet to receive a response and would love to have it up and running to track the team's Q2 progress against goals in the one space.
Are we able to get some assistance on this please?
HI @Tomas Ryan , we currently have an issue/bug with turning on this integration on new sites. I think it's still going to be a couple of weeks before we can fix it. Sometimes it works if you refresh your screen a few times, sometimes not. We'll fix it, our apologies!
Hi, I seem to be unable to integrate Jira Software with Jira Product Discovery, please can you advise? I can see documents relating to integrating Confluence but not Jira.
Hi @Dave Noble , is that about the Atlas integration?
If you're asking about Jira Software and Jira Product Discovery, then:
Yes sorry my mistake.
I can't surface the Atlas Goals and Projects in Jira Product Discovery, how do I get that integration working?
OK, gotcha. I just turned it on for you. Refresh and that should work.
Demo here: https://www.loom.com/share/9489c20d9ff243cd95882bf4c502ba87
Many thanks for this but still not showing, I have refreshed and checked across projects in JPD but still unable to see any Atlas fields.
Really appreciate your support in fixing this.
Dave
Hi Dave, it's definitely turned on. Sometimes it takes a few refreshes before the fields actually get created (one of the reasons it's still in early access). If it's not working by end of day tomorrow please let me know
Hi Tanguy,
Okay so some progress made but the Atlas fields are inconsistently showing across the projects and views.
So in one view within one project, I can see the option for all Atlas fields. But in a different view in that project I can only see one Atlas field.
In another project I can't see the option for the Atlas fields at all.
Appreciate your help here
@Dave Noble I think we'll need access to your site to investigate what's going on.
Could you please raise a support ticket?
@Tanguy Crusson Cold you please turn on the JPD -> Atlas integration for our site computas.atlassian.net ? This is such a nice feature :)
@Tanguy Crusson hello! I'm also encountering the issue where we cannot link Atlas Goals with JPD ideas in the Overview tab. Is this something you can also turn on for me?
@Tanguy Crusson Would it be possible to get access to the atlas / product discovery integration?
Hi @Tanguy Crusson, Is there some documentation of the Atlas/Jira Product Discovery integration available somewhere? I had hoped to find it here. Thanks!
@Kelly Arrey details here: https://community.atlassian.com/t5/Jira-Product-Discovery-articles/Upcoming-product-improvements-Atlas-integration-ready-for-early/ba-p/2195274
And i've turned this on for your site
Thanks @Tanguy Crusson !
@Don Cosseboom @David Hartman @Ellen Daleng I've turned it on for you too.
For anyone else who wants access in the future - please ask by commenting here: https://community.atlassian.com/t5/Jira-Product-Discovery-articles/Upcoming-product-improvements-Atlas-integration-ready-for-early/ba-p/2195274
Thank you so much! Looking forward to using this. Honestly, JPD is one of the best things Atlassian has come out with recently. Props to the team.
How do I get the JPD-Atlas integration work for us?
Done. Anyone else, please ask directly here: https://community.atlassian.com/t5/Jira-Product-Discovery-articles/Upcoming-product-improvements-Atlas-integration-ready-for-early/ba-p/2195274 - it's getting hard to manage requests across many posts
