Customizing the Create Issue Screen
Sholie Shallom April 18, 2023
I am looking to customize the Crease Issue screen to only display relevant fields for the product managers to enter only relevant information while creating the idea, is there a way to customize the create issue screen ?
2 comments
CC
April 18, 2023
@Sholie Shallom I worked around the issue by creating a view and calling it "Create View".  Then told my teams to make sure they clicked on the view before they clicked the blue "Create an Idea" button.  Then I told them to just focus on the fields in the "Fields in View" group on the right hand side.  Seems to be ok so far.  I'm also funneling everyone to the blue button until the other user levels are sorted.
Like • Tommy Légaré likes this
Sholie Shallom April 20, 2023
Thank you, it is a good starting point, I am planning to implement it
Jan-Hendrik Spieth
April 19, 2023
Thanks, how do I get this enabled for my instance. This will surely help what I am looking for
Jan-Hendrik Spieth
April 20, 2023
Bummers, I see now the testing slots are currently all taken. Looks like you'll have to wait for the JPD team to either take in more testers, or release the feature ... :-/
