Is there a way to map Ideas in advance roadmap ?
Erion Peci
Hello
I wanted to map ideas as issue type in the advance roadmap in issue hierarchy above epics . Is there a way I can do that ? Is this a feature you are working on .
What I am trying to solved is two things the first thing is being able to produce a timeline/ roadmap . And secondly I have avoiding the amount of work and duplication by creating an other issue as initiative and then linking all epics to that initiative when I have link those epic in the Jira discovery already . I have tried to link the initiatives  under Ideas in Jira discovery but that does not roll up the story points so the progress is inaccurate.
Erion
3 comments
Curt Holley
Hi @Erion Peci
Not currently. Until Team managed projects are available in Advanced roadmaps, I don't believe this will be possible. Though @Tanguy Crusson may have other ideas/info???
Like Tanguy Crusson likes this
Tanguy Crusson
February 25, 2022
@Erion Peci you can definitely link initiatives (or other issue types created in advanced roadmaps) to Jira Product Discovery ideas in the delivery section, however you're right in that delivery progress is currently calculated using the number of children ideas, not story points.
Tanguy Crusson
February 25, 2022
Oooh never mind, I misread your question - you cannot yet use Jira Product Discovery ideas in Advanced Roadmaps, to visualize them there alongside ideas.
On that topic we're currently working on a timeline view for Jira Product Discovery, and discussing a deeper integration with Advanced Roadmaps.
Like # people like this
Erion Peci
Thank you @Tanguy Crusson  looking forward to that integration.
Erion
ngonzalez May 15, 2025
I found that we cannot add an idea as part of the hierarchy, but we have a filter for the ideas and this could be good enough. :)
