Hey Everyone,
How do you manage the Affected Customers in JPD? Currently, this is a multi-select which doesn't seem to work properly when the list of options becomes very long and it's hard to re-order it (drag'n'drop doesn't work below the ideas list area, only the move up or down seems to work but it's time-consuming to use it). Do you have other suggestions or use a different field type for that? I'm curious how others are doing it.
Hi Rohan,
Nice to meet you! I'm looking for a way to track interest in ideas. The Affected Customers field helps me to see who has requested a feature however it's hard to manage the multi-select list so I'm wondering if there are alternatives.
In a past life with a different product, I collected the actual customer affected (if known) and assigned it to a category (a persona). Then I could see if a certain group of customers were more affected or cared more than others (helped with pricing conversations especially).
I don't have a good way of doing that yet here.. so I'm using a "Key Customers" field which is a multi-select and I've populated it with core personas we focus on as a business.
I'm not tracking individual customers, though in the future being able to assign that when known would help with closing that feedback loop on delivery.
My two cents.
Thanks for that insight @Kasia Karska [HeroCoders] @Krystal O_Connor here are a few options:
None of these are perfect though, as a product management team we'll take your use cases into consideration.
@Kasia Karska [HeroCoders] that's on top of the suggestions already made above by @Rohan Swami
We are currently improving the select/multi-select fields to behave well with a large list of values. As you mentioned, currently it doesn't work well when there are a lot of values (it's super slow). We expect the improvement to land in the next few days.
@Kasia Karska [HeroCoders] I just turned on the new version of the multi-select field for you - makes it easier to manage a large list of values in the field configuration (the dropdown for selecting them will still be slow though, we started working on that too). Can you let me know if you see a big improvement? (also need to make sure I turned it on properly for you)
Awesome!
