It would be really great to be able to have a filterable list of issues off to the right side of the timeline view that would let me drag and drop onto the timeline. This would really help on the estimating side of how things are stacking up. The alternative, is two windows open, and trying to update the dates to get them on the board, etc.
(using the "Find an idea in this view" search field is often my go to way to find an item so a searchable list would be excellent).
Does this happen to be in the plans, or maybe a weekend hackathon :)
Yes, did you mean this @Brent Vierling ? Or is this experience missing something for you?
Whoa, I didn't see that. Thanks @Sabine Lambrecht and @Tanguy Crusson
That is what I was looking for!
Thanks Brent, this actually helped settle an internal debate today 🙂
@Tanguy Crusson know its been a couple months, but if helpful, I also just spent quite some time doing this the wrong way. REALLY glad I stumbled across this so now I know not to do that in the future... wish I had searched the forums first!
Oh damn, I had missed this also! That's very useful.
Though I would like the ability to filter the list ideally.
If you apply a filter on the view, then it will filter the list as well as the ideas showing in the view
