×I am reaching out with a query pertaining to the development of the new Jira Product (JPD). As a dedicated user of Jira Software, I have found the feature of creating and saving quick filters for specific views to be incredibly useful in streamlining workflow processes.
I am curious to know if the functionality of quick filters will also be integrated into the upcoming Jira Product Development platform, or if there is an existing equivalent within JPD that serves a similar purpose. The ability to swiftly create and save filters has significantly enhanced my productivity, allowing me to focus on key tasks without unnecessary navigation complexities.
Hi Eduardo,
We don't have this feature on our roadmap for the moment, as as Iryna mentioned, in Jira Product Discovery you can create your own views, so you can create any combination of filter/group and sort and save it as a view, so then you can easily navigate between these views without recreating filters every time.
The quick filters are very useful on a backlog, during a sprint review & planning for example, so something frequent where you need to assign things quickly to specific individuals, but you don't generally need to switch between filters so frequently on a yearly roadmap.
Could you please let me know which type of quick filter you'd like to see on your ideas in Jira Product Discovery ?
Best Regards,
Hermance
Product Manager @ Jira Product Discovery
@Hermance NDounga Ed and I are on the same team so I'll answer this.
We use one JPD project to maintain all roadmap ideas. All work and iteration on ideas happens in JPD until it's ready for execution. Our Product team does weekly check ins to make steady progress on work/ideas, make sure statuses reflect reality, remove blockers etc getting the ideas ready for delivery (our own version of scrum).
It's super helpful to quickly filter by Assignee, or Teams, or Category, (or a custom field for Business owner) without having to modify the view and without seeing all the irrelevant ideas.
Two additional thoughts:
Creating additional views (e.g., one per team or one per PM) is a workaround but I can see it proliferating endlessly and it's not scalable.
Happy to walk you through our setup so you can better understand the use cases. I see the above as critical to making JPD a more functional tool for daily/weekly work and improve roadmap usability/share-ability across the organization.
Hey Sabina
Thank you for your answer, if you are using Jira Product Discovery to make these types of daily/weekly meetings, then it does make a lot sense indeed.
To address your two additional thoughts:
The contributor role is very recent, and while we are currently working on introducing the stakeholder role, to make sure you can share Jira Product Discovery views even with users who are not in your site, we will definitely make improvements on the contributor role and their experience in Jira Product Discovery.
For the workaround on quick filters, I'd suggest you disable the autosave on the view you are using .
You won't be switching between users as you would with quick filters, but at least, the modification you'll made on the view during your meeting are only seen by you, and no one else :)
Cheers
@Hermance NDounga thank you for the reply!
Super important question right now since we are ramping up JPD usage and telling everyone in the company how great it is:
What is your recommendation for now to help Contributors see a specific cut of the ideas? Is creating new views the only option? One view per business owner or engineer (or even each Eng team and each department) is already a lot, and then people will want timeline, list etc.
Other quick follow ups:
