Shared Views (Creators, Contributors and Stakeholders)
Gavin Steele
Some additional control on visibility and editability  would be nice.
Freeze column(s) in a specific view
I would like to be able to 'freeze' columns in a view. This would render the data in that column on that view only, read-only.
I am setting up views for multiple teams, but pull in related columns for reference or guidance. I want to prevent some creators from editing some columns in that view (by mistake mostly, but they might think they relate to their work).
Column specific edit options
I have a number of PMs in one view (Single product area), I would like to restrict edit access to a specific column to creator. For example, the team lead assigns work, so I would like to restrict that field to the team lead.
Create Form
I would like to be able to lock down the view that is used by the create form. This prevents changes and errors to be made.
I would also like to be able to include fields on that form that are set with a default value and not visible to the form.
0 comments
