Sign up Log in
What are some ways to Copy Key Customers to JSM
Robert Lanckton
Our Feedback process has an JSM board where the delivery ticket is created, then converted into development issues. Our developers and product team will not refer to the Idea, so we need to include as much information from the Idea into the JSM issue as possible.
What are you all doing when creating Delivery Tickets where you believe the Key Customers should be included in the delivery ticket? I can't think of a way to accomplish this outside of including it in the Delivery Ticket Description.
Any other ideas?
2 comments
Tanguy Crusson
April 3, 2023
@Robert Lanckton as with most use cases that are very specific to the workflow you configured, I think your best option is to configure Automation rules. There are a few examples in the FAQ https://community.atlassian.com/t5/Jira-Product-Discovery-articles/Frequently-asked-questions-about-the-product-how-do-I/ba-p/2002378 (search for "Automation" in there)
Robert Lanckton
Absolutely will be planning on building out automations for this purpose, I'm just not sure where the Key Customers field would translate best to in a JSM project, since there isn't a similar field in JSM.
I think I could add it to the description as words, but that strips some of the data viability and filterability.
Tanguy Crusson
April 3, 2023
Ah ok, gotcha. You might be able to create a corresponding custom field in your JSM project, and keep the options of that field in sync with automation, but I've never try. Maybe worth a try?
Robert Lanckton
Thanks! I found two solutions - it loses the weighting, but it still captures the important part.
Robert Lanckton
I'm noting for anyone else who's curious, I wrote an automation which copies the fields to to a Checkbox list in our Development JSM Project, since JSM Cloud doesn't support multi-select drop down and they're functionally the same.
I also wrote an automation to replicate the behavior Labels in case the JSM project doesn't include a Checkbox Field one can use already, which also replaces spaces with underscores.
If anyone is interested in the automation rules let me know :)
