Hi all,
I am planning to deploy the production environment after the stage of testing.
Could you advise me that could we deploy a test environment (remaining for further testing) and the production environment on the same server?
And my next concern is that there is any way to clone the testing environment to the production (with all data/files)? And still, keep these environments working separately (I think can do it via different port/folder).
Furthermore, I am expected that the production working on Microsoft SQL Server for the database configuration. There is any impact on my setup, is it?
Any help will be completely appreciated.
Thank you.
@Quoc Nghia, TRAN I highly discourage you from running Prod and Test on the same server. In fact, don't run anything else on the same server. I recommend Jira and Confluence on their own servers, and Jira Test and Confluence Test on separate servers.
