×I have set up an Active Directory server directory to sync with (Read Only w/ Local Groups) - I can disable/re-enable the directory under user management, trigger a sync, and all users will appear (approximately 350).
However the users will disappear every time, sometimes this happens immediately, sometimes it may take five minutes.
I have noticed that once I have used an account from my active directory (as an issue reporter) it is added to the internal directory. However shortly afterwards, the username gets crossed out and has "(inactive)" listed underneath it.
EDIT: I am trying to sync up my users as customers only. That way they are able to log into the customer portal with their AD credentials, and I don't have to send them an invitation.
SETUP:
JIRA Service Desk 3.14.0
JIRA Core 7.11
Running JIRA on-premises (Windows Server 2016) connected to a separate database server running Server 2012 with SQL 2014.
I ended up disabling the AD user directory I created, and created a new LDAP directory. Everything is now working as it should.
Have you Created groups in active directory /LDAP in which users will belong to in oder to be able to access jira SD (for example active_jira_users, active_confluence_users), application access must also be configured in your Jira SD server using these groups
Best!
I am currently using the "domain users" AD group - I did try creating a separate group (i.e. Jira users) but I ran into the same results.
I have also assigned the accounts (within the AD group) the "service desk customer" role within the project.
The problem is that the accounts disappear shortly after I go through and grant them permissions.
@Justin W Culbrethhave you configured the same group in AD to be in application access in your JIRA SD if yes then it should synchronize without any issues and user should not disappear because they are in this group in AD.
The AD group that all of my users belong to is listed under the "Service Desk Customers" role for the project -
So do you have the same groups configure in JIRA SD in application access ?
So now I'm very confused, these are customers that I am trying to sync into the system - do they require "application access" as defined by Jira? Adding them on that page simply gives me an error regarding my license count
@Justin W CulbrethIn application access you have the group jira-service-desk-users so in AD you should have the same group name to allow syncro and user must be in this group in AD.
Right but those service-desk-users count against my licenses -I'm simply trying to sync up customer names and logins so that they can log into the customer portal using their AD credentials.
Great ! that it works ! fine now, please mark this question as solved/accepted so that others can use answer here.
Best!
