Add customer to group in post function using ScriptRunner
Paul Mata
I would like to do check new customer accounts (when their first ticket is created) for a specific email group (i.e. find anyone with an email address from "@example.com") and add them to a specific group.
I have ScriptRunner installed, but I have searched all through their tutorials and examples and can't seem to find anything that would solve this problem. I think it would be as simple as putting a script in the create post function with the following logic:
if email address included "@example.com" then
set group = "distributors"
The part that I can't find is how to look at the email address of a customer/reporter.
Hana Kučerová
February 6, 2021
Hi @Paul Mata ,
yes, custom script post-function on create transition should work, please try something like this:
import com.atlassian.crowd.embedded.api.Group
import com.atlassian.jira.security.groups.GroupManager
String USER_GROUP_NAME = "distributors"
String USER_EMAIL_PATTERN = "@example.com"
GroupManager groupManager = ComponentAccessor.getGroupManager()
ApplicationUser reporter = issue.getReporter()
if (reporter.getEmailAddress().contains(USER_EMAIL_PATTERN)) {
Group group = groupManager.getGroup(USER_GROUP_NAME)
if (!groupManager.isUserInGroup(reporter, group)) {
groupManager.addUserToGroup(reporter, group)
Paul Mata
@Hana Kučerová this worked perfectly! Thank you so much for your help.
Like Hana Kučerová likes this
SERVER
VERSION
4.14.1
