Recently updated our Jira DEV environment from 4.8 to 5.4.
After that, the comment restriction menu displays incorrectly.
Please see screenshots.
I tried to disable all plugins, but it didn't help.
How can I fix it? Please suggest.
Note:
I've noticed that if Jira SM get installed from scratch with empty database, the comment restriction feature is not available at all, and I didn't find how to enable it.
Michael
Jira SM 5.4 (the expanded list is too narrow)
Jira SM 4.8 (displays correctly)
Hi @Brant Schroeder, thank you for your answer.
I mean, when a user clicks on the padlock icon on a comment field the list of groups/roles shows up, but the high of the list is a few pixels. Please find it on the first screenshot. I highlighted it.
@Michael Smith Here is some information on how to add or remove comment restrictions https://confluence.atlassian.com/jirakb/add-restricted-comments-on-jira-962353957.html
Can you please explain what you mean by not displaying correctly?
@Michael Smith have you cleared your browsers cache?
@Brant Schroeder Sure. I've cleared browsers cache, opened it in incognito mode, tried different browsers, disabled all plugins - nothing help. All our users are experiencing this issue.
I've tested newer Jira SM versions - 5.4.1 and 5.5 - the same.
@Michael Smith Have you cleared the app (plugin) cache in Jira? https://confluence.atlassian.com/jirakb/how-to-clear-jira-s-plugin-cache-1157468195.html
@Michael Smith I would suggest submitting a support issue to Atlassian to see if they have seen this before or can see any issues in the support logs. https://support.atlassian.com/contact/
