Sign up Log in
Assets Object mapping not working with children of inherited object type
Leonie C_ Breitmoser
Hi all,
I struggle with the following issue when importing data in assets from a postgres db.
I can't manage to import references to an inherited object type.
My scheme tree:
  • Abstract Objecttype "All OL"
    • child objecttype "OL1"
    • child objecttype "OL2"  (Attribute should be "Parent OL" = OL1)
    • child objecttype "OL3"  (Attribute should be "Parent OL" = OL2)
"All OL" has an attribute "ParentOL" as object reference to "All OL" (checked option "include all children") .
My issue:
I have three different import configurations for each child one. Each child has a parentol in the database, which I want to see in the Parent OL.
The object mapping to the attribute in the import configuration looks like this:
Datalocator = parentol |  Assets Attribute -> ParentOL | Object mapping AQL ->"OL ID" = ${parentol}
I tried it with a normal attribute that just refrences to the "parent ol" directly and not uses the inherited objecttype and that works well.
Anyone an idea what I do wrong? Or is it not working at all?
I solved it with an automation and a script, but I want to understand why it's not working.
Leonie
3 votes
Hi all,
here's an update. I found the mistake I made in the setup.
The referenced attribute was not indexed. With the following setup it works!
SERVER
VERSION
9.4.1
atlassian, atlassian community, journeys for jira service management, journeys for jsm, eap jsm atlassian, early access program atlassian, early access program journeys atlassian, early access program journeys jira service management, join atlassian eap
Join the Early Access Program (EAP) - Journeys for Jira Service Management 🚪
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →
Upcoming Jira Service Management Events
