Automated Linked issue to another with a custom field value
Dominic Peters
Hi Community,
i tried to find a custom field like an "Issue picker" but that dont exists actualy. I have a case there someone creates a ticket and fill in a custom field a correkt Ticketnumber from the past.
Is there a possibility to fill in the "issue" field under the popup from Linking an Issue with the value of a Custom field?
The outcome should be i fill a field like "old ticket number" with a value like "TEST-123" and the created ticket is automatically linked to this one.
I tried something like this with a smart value of the custom field, but the automation didnt find the values.
I inserted a simple RE-Fetch issue condition to avoid the bug with the fast issue Created trigger. But i dont know if this works basically. I hope you understand my bad english :)
Florian Bonniec
Hi @Dominic Peters
Have you try to use {{issue.customfield_16810}} ?
Also you may try to do a Branch selecting JQL and using the following JQL "key = {{issue.customfield_16810}}". Then add the action link issue between issue and triggerIssue.
Regards
Dominic Peters
Hi @Florian Bonniec
many thanks now it works totaly fine with {{issue.customfield_16810}}.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
