Automation - Custom field value trigger does not trigge
Dmitry October 28, 2022
We have a custom field that's added and changed by an app "Customer Satisfaction Survey for Jira".
Here is an example of the field and how it looks like in Jira:
The field value is updated, but we don't see this in the Issue history.
That is automation with a field value change trigger does not work in this case.
The change itself can be tracked through JQL the scheduler, but we need to get up-to-date data on issue.
I would like some advice on how to get this trigger to work.
Stefan Salzl
Hi @Dmitry
it seems kinda „special“ that the change doesn‘t even occur in the issue‘s history.
As this is a specific change by an app and not „native“ jira i would recommend to reach out to vendor‘s support to clarify how fields are changed (technically) and why those events are not fetched by the jira engine.
Best
Stefan
