Automation Rule to add a comment - Can I use smart values?
Ricardo Gomes
March 14, 2018 edited
Hi, I'm using Automation within Service Desk (not Automation for Jira) and creating a rule that adds a comment to a linked issue whenever it is transitioned. However, I'm not sure I can use smart-values there such as {{#changelog.Key}}{{fromString}}{{/}}. It's actually confusing because of all the Wiki type of formatting which also uses brackets.
Meg Holbrook
March 14, 2018
I haven't found a way to do this through automation. Unfortunate, to say the least.
You mentioned Automation for JIRA add-on, which is what I use (and has worked fabulously).
Ricardo Gomes
Thanks, appreciate your response.
I'll try and build it using the add-on instead.
