Automation Rule using Team field
Antonina Yudina
hey guys,
I m trying to create an automation rule using the Team field which looks as following.
Trigger: creation of a new issue
When: issue type is one of the following: Story, Epic, Task
Then: advanced option:
    "fields": {
    "customfield_10001":"TEAM-ID"
Result: No Team Name is added when a new issue is created :(. Any idea why?
Thank you in advance for your help.
7 votes
Yogesh Mude
July 11, 2025
@Antonina Yudina below should work...
{"update": {
"customfield_10001": [
"set": "f6c675e0-f944-482c-955c-0d265dc9285b"
Note, please replace your team ID
Antonina Yudina
the field Team in a new Jira issue is still empty :(
Like John Funk likes this
Yogesh Mude
July 11, 2025
Ahh, strange. The above code is working in my instance. not sure why its not working for you.
Yogesh Mude
July 11, 2025
Also, as @Tomislav Tobijas  mantioned share the rule + audit log.
Like # people like this
Antonina Yudina
Antonina Yudina
Audit Log looks perfect - Successful
Like Laurie Sciutti likes this
Yogesh Mude
July 11, 2025
Great.
Antonina Yudina
the field is still empty although no errors shown in the audit log. I dont get it.
Yogesh Mude
July 11, 2025
can you share the work item snap and team as well. BTW, Team field is availble on the work item create, Edit screen? if not, then please add and test.
Antonina Yudina
Antonina Yudina
hey guys, it works :)))). but not immediately. it takes Jira kind of 1-2 sec to add the team name. Thank you all for ur great support!!! u r just amazing ;)!!!!
Marc - Devoteam
July 11, 2025
Hi @Antonina Yudina
The syntax is as follows:
"fields": {
"customfield_10001": "<team-id>"
Tomislav Tobijas
Hi @Antonina Yudina ,
This should work, though. We're using the same thing/JSON and automation updates Team field value. We do additional mapping via Lookup table, but it's the same thing as defining an exact team ID.
Could you please share a screenshot and audit log from your automation to help debug what's going on there, if possible?
Tobi
Richard A. Michaels
In a Create a new action of my automation, I'm creating an Epic in a different project than the trigger project.  I'm only concerned with specific teams so I can check for specific team IDs in my IF criteria.
In the additional fields section, this seems to work for me
"fields": {
"Team": "<<team-id>>"
