Automation rule with custom fields
Hoa Nguyenthi August 31, 2018
why this rule does not run? do you have any suggestions?
undefined
Hoa Nguyenthi September 6, 2018
It still work if I separate this into two rules. Do you have any suggestions on this?
Hoa Nguyenthi September 5, 2018
Hi Jack,
Thanks for your comments.
I checked and see that the request type is matching and the Subsidiary only has 3 values (QUOINE CORPORATION, QUOINE VN AND QUOINE PTE)
Hoa Nguyenthi September 4, 2018
I edited the rule but it still does not run :(
Jack Brickey
The match legs are both failing and as Vic point out there should not be a difference in “request type” so I would edit both and it should give you the option to select request type vs. typing it in. Second I would have to guess that either the request type is not matching or the subsidiary is not in both cases. Are there other valid values and what is the action under those cases?
Victor Mutambuki
August 31, 2018
Hoa,
1. I noticed that the Issue types are different. One is spelt "request type" and the other "Request Type". Could this be an issue?
2. Have you enabled the Rule?
victor
