Business Process Mapping
Fi Passey April 20, 2021
We already use JIRA Insight to hold details of all our assets and suppliers but we need the ability to hold process maps aswell. Is there any functionality in JIRA for business process mapping using the asset registers in Insight as the building blocks? Many thanks
Dirk Ronsmans
Hi @Fi Passey and welcome!
Could you elaborate a bit on what you'd like to do?
i've been looking into the same/a similar use case myself to create process flows within Jira depending on a Request Type. Sadly that doesn't exist in Jira and the flower app (cloud only for the moment) seems to be the only option (unless you want to start scripting a lot!)
But maybe your use case is different, could you get a bit deeper in to your requirements?
Fi Passey April 21, 2021
Hi Dirk,  we're looking to create process maps to understand the dependencies on systems, teams and suppliers along an end to end process. We use Insight to hold details on all systems, a supplier register and all teams so our ideal solution would be linking these libraries to the process map. Visio and Draw.io are fine but they are static and unstructured. I am going to investigate the flower app. Best of luck!
Tanja
@Dirk Ronsmans
we use flower app with Jira DC, so looks like it is not only for Cloud.
If you are looking for a business process mapping solution, you can give it a try.
G subramanyam
Hi @Fi Passey welcome to the Atlassian community forum.
At the moment Atlassian products have good number of market place tools to integrate and work seamlessly.
Having said, for JSM I found flower-workflow-automation tool with good rating, contact support. FYI, access the tool's Documentation if that fits your need.
Stay safe and stay healthy.
Many thanks - very helpful. I will check out the flower app.
Like G subramanyam likes this
Daniel Bungre
December 12, 2022
Is there somebody I can send a high level RFI question file to for completion?
We are shortlisting solutions for the RFP stage.
Kind regards
Daniel Bungre
Technology Procurement Manager
Poundland Ltd
Dirk Ronsmans
@Daniel Bungre
You might want to reach out to a partner in your area to complete your RFI question file.
https://partnerdirectory.atlassian.com
Like Daniel Bungre likes this
loom essentials certification, loom training, get certified in loom, atlassian certification, loom async video, video messaging skills, atlassian learning, loom for teams, online certification, loom badge, loom for business, atlassian education
Get Certified in Loom! 🧑‍🎓
Time to up your Loom game! The new Loom Essentials Certification is here! Show off your skills, learn pro tips, and get officially recognized. Perfect for taking your video messaging to the next level.
Learn more
