I'm currently using the Cloud free Jira Service Management and try to set it up before migrating our teams to this new tool. I'm clearly a newbie with Jira.
I want to create an automation rule that will update a custom field when the issue is created. The goal is to compute an URL based on the issue ID.
After creating, a new automation rule for my project, I'm trying to publish it and I have the following error:
There was a problem retrieving permissions from your Jira instance. Please try publishing this rule again.
I can retry and retry again I always have the same error and the rule is not published.
The exact same rule can be added as a gloabal automation rule but it does not get executed for my project. If I try to change the scope of this rule from the global automation rule screen to the scope of my project I get the exact same error above.
Any solution?
Thank you,
Guillaume
Hi, I was facing exactly the same error message "There was a problem retrieving permissions from your Jira instance. Please try publishing this rule again."
I was able to create rule for whole organization, not to 1 project. Even this way was the rule not being applied.
Nothing I have tried help, I have even opened the ticket to Atlassian.
The next day were all previously created rules were gone. So I have tried to create (import) rules again and they were working.
Time has solved it for me.
We are also experiencing this issue. There was a problem retrieving permissions from your Jira instance. Please try publishing this rule again.
I have checked permissions and I have sufficient privileges to do the automation setup
Hi David,
Unfortunately it was not. I'm discussing with Atlassian to get support on this.
Best regards,
Guillaume
Have you already checked the permissions schemes for your project?
Do the following:
Access the project settings and click on "People", add your user in the project role "administrators".
Then go back in the project settings and see "Permissions", ensure that the project role "administrators" and "addons" are included in "browse project" and in "Edit issue".
If this is corrected, please bring us a screenshot of your automation framework for us to evaluate.
Hi Fernando,
My user has already the project role administrators. Role administrators is already included in "browse project" and "Edit issue".
By the way, I did not modify the permission scheme for my project, so it is inherited from the default "demo" project created when I started to play with Jira service management.
Please find attached the screenshot. Here I'm trying to add the automation rule from the global automation screen with a scope limited to my project. Same happens when trying to add an automation rule directly from my project's automation screen.
Thank you,
In this case, I recommend that you contact Atlassian support to evaluate.
If your user has all the profiles and permissions, this error seems to be a bug of the system not recognizing your permissions.
The support ticket you can open here: https://support.atlassian.com/contact/#/
Thank you Fernando.
Unfortunately while I'm still on the Cloud free version I cannot open support request.
Can you verify if this behavior is repeated in another project?
If it doesn't happen in another project, you can create a new project by copying the structure of the current one, so you don't lose all the details.
Yes same problem. I contacted the support to extend my free trial and talk to them about the issue, I'll see what they can do.
Thank you very much for your help.
You're welcome! I hope they can get this resolved soon. Have a good day
Hi Fernando,
I am having a similar issue with automations I migrated from one instance to another. Was your issue resolved and if yes, how?
Hi David,
I too am having this issue with automation, I too migrated from one instance to another.
Have you got any answer, David? was the problem for u resolved? If yes can u Guide me?
Thanks.
