Disable Remaining estimate and Comment on Screen
Saad
Hi Folks
Is there a way to disable/hide the Comment and Remaining Estimate on a Transition screen?
I cant figure out a way to disable them from the screen.
Jack Brickey
Yes.
  1. you need to be admin
  2. go to the workflow that is associated with the issuetype you wish to modify and go into edit view
  3. double click the transition that you are interested in
  4. determine the screen that is used during transition
  5. exit out of the workflow without making changes
  6. go to screens and find the one noted in step 4
  7. edit and remove the desired fields
Saad
Thanks @JA I did exactly that, but these system fields are not even shown as options. Which means I cant delete them...any idea why?
Tom Lister
Hi @Saad
The comment field is always shown on transitions
The estimate field will be called Time Tracking
