Hide - add comment on issue screen
DG September 4, 2023
Hi togheter,
We want to hide the "click to add comment" option in the UI?
Is there a way to do this, via JavaScript for example?
Best regards
DG
Fazila Ashraf
Hi @DG
You can try using the script fragments from scriptrunner plugin  for this usecase -> https://docs.adaptavist.com/sr4js/latest/features/script-fragments
Rilwan Ahmed
Hi @DG ,
Two workarounds I can provide.
  1. Grant add comment permissions only to required users.
  2. If you want users from adding/block comments at particular status,  then add workflow status property
    • jira.permission.comment.denied -- disables comments when an issue has a particular status.
    • Allow comments from the groups jupiter and mars:
      • jira.permission.comment.group.1=jupiter
      • jira.permission.comment.group.2=mars
More details about property is in https://confluence.atlassian.com/adminjiraserver/workflow-properties-938847526.html
SERVER
