I have created a workflow type called implementation. I also created an Issue Type of Implementation. I cannot seem to add multipe Issue Types to a single project.
Inside your project, hit the settings on the bottom left toolbar, and select issue types.
There you can select the "Actions" button and cog at the top right - then click "Edit Issue Types" which will bring you to a selection screen where you apply/remove issue types from your project.
