How to disable editing for closed Jira issues (cloud)
Dreymann, Thomas
Hi all,
after a ticket has been closed, i would like to prevent users from writing new comments and editing their own comments.
I read tons of article and saw many solution for server like changing parameter in our workflow i.e.: jira.permission.comment, jira.permission.comment.user, jira.permission.edit.denied. But I could only get it working that you can no longer edit an issue, the comment always remains editable.
Hopefully there is one with a new idea of solution?
Best Regard
Thomas
Dreymann, Thomas
thanks all for helping - this was the solution for me.
Marc - Devoteam
November 10, 2023
Hi @Dreymann, Thomas
I use the properties as well.
I usually set the following properties depending on the use cas.
If I want to make sue an issue can't be edited on the final workflow status I use:
Key jira.issue.editable with value false
If I want to make an exception, lets say for group jira admins, I use:
Key jira.permission.edit.user with value jira-administrators
Joseph Chung Yin
@Dreymann, Thomas -
Based on my understanding and experience, editing existing comments when the issue is closed can't be controlled.
Here are additional WF properties for your reference - https://support.atlassian.com/jira-cloud-administration/docs/use-workflow-properties/
Sorry.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Sanjen Bariki
November 6, 2023
Hi @Dreymann, Thomas ,
Welcome to Atlassian community!
Could you please go thorugh the below document to for the resolution..?
Kindly check and let me know If you have any quries.
Please accept the answer If it helps you.
Sanjen Bariki
Dreymann, Thomas
thanks for helping me - these documentation I also found and I made ff. changes to our configuration:
the result is, as I mentioned above, that nobody could edit this issue and make a new comment after closing this ticket. But, if I have make a comment before, I can edit this comment after closing the issue.
Maybe the server solution is different to cloud?
Thomas
