How to get linked issues customfield values (Project Automation - Smart Value)
info_intercomp_ru December 6, 2019
My project has 3 tasks. Two of it are linked with 3d by "is blocked by":
1. 1st's linked with 3d by "is blocked by";
2. 2nd's linked with 3d by "is blocked by";
3. 3d's linked with 1st and 2nd by "blocks".
I use {{issue.issuelinks.first.inwardIssue.customfield_id}} - Project Automation. But it returns only first linked issue field's value.
How to get all "is blocked by" linked issue field's value? Not the first value only?
Screenshot attached
Alexander Bondarev
December 6, 2019
On first view - it look like you have cicle, because in "conditions" you searched linked issues, then you just should edit them. (you are editing again linked issues). Maybe you right - depends on your case. Just advice.
Alexander Bondarev
December 6, 2019
Hi!
Not sure, but if believe in logic, try -  {{issues.issuelinks.inwardIssue.customfield_id}}
Or try to delete "first." from your example.
Привет, Александр!
Не работает, если удалять first. Плагин выдает ошибку
Alexander Bondarev
December 6, 2019
Have you tried my first version?
Like tolkit likes this
Tried. No result. Got error.
Alexander Bondarev
December 6, 2019
Can you show screen with an error?
Screen attached (cut off internal information).
Alexander Bondarev
December 6, 2019
What do think about cicling, like I wrote before?
Because at the screen another mistake.
So I think my answer about syntax can be right.
