I need modify a Screen of system. about the Sub-Tasks
Rafael August 28, 2018
When you open the form of a task there is a section
where you can see the subtasks associated with this task with some fields.
I would need to be able to add a couple of customfields in this section,
but from that screen these sections do not appear,
neither the sub-task nor the comments section.
Jack Brickey
This is not possible unless you wanted to modify the code.
Rafael August 29, 2018
now i know this property jira.table.cols.subtasks of system that edit column of subtask issue tab.
