Does anyone know if it's possible to circumvent the max results of 25 on an API call to Insights?
I've struggled with a max result of 25 for so many things in Data Center and I cannot find any information about whether or not there is a param that can be passed. MaxResult does nothing, and the documentation for Insight API for DC is some of the worst stuff I've ever seen.
Hopefully someone can help!
Hi @Troy Chaplin ,
I'm not sure which version of Insight do you have and which endpoint do you need, but have you tried resultPerPage param in combination with page param?
I've found it in the iql endpoint documentation.
Thank you @Hana Kučerová , I overlooked resultPerPage and was trying to use maxResults like other endpoints
