I have 2 Insight object/s custom fields. First field has objects selected and I want user to only be able to select these objects in the second field. I added this filter:
Works fine in Jira:
Doesn't work on customer portal:
I'm using Workflow Actions plugin (Actions for Jira Service Management) to display transition screen on portal.
Hi @Gleb Kartashov ,
Is insight enabled for customers? In the schema permission it should be an option to allow customers to interact with custom fields
I would try to re-index Insight. If not working a instance re-index.
If you are on DC, try in a different node in case is a replication issue.
Otherwise, I would suggest to report it to Atlassian.
As a workaround, you can create a group and add it with all your customers and then to the users group for Insight. Please note customers will have a bit more access than usual, so better test it to know all drawbacks
