Insight import url not accepting spaces
Claire Berry
I am trying to configure an insight import using a JSON import type and pointing it to a URL.
This url works fine for the endpoint in postman, but in jira when testing the configuration, I get the error "Failed to connect to the JSON file specified"
From altering the url, I have found that the issue is due to there being spaces in it.
My url looks like this:
http://example.net:8080/iiq/scim/v2/Entitlements?filter=application.displayName eq "OKTA"
and I believe it's failing at the last part. I have tried variations of this I found online but can't get anything to work. Is this a limitation with insight imports? Or can anyone advise how I can get this to work?
Claire
4 votes
Fabio Racobaldo _Herzum_
Hi @Claire Berry ,
you need to encode the URL your filter should be something like filter=application.displayName%20eq%20%22OKTA%22
Hope this helps,
Fabio
Claire Berry
Hi @Fabio Racobaldo _Herzum_
Thanks for the reply.
I did try what you suggested:
http://example.net:8080/iiq/scim/v2/Entitlements?filter=application.displayName%20eq%20%22OKTA%22
I also tried:
http%3A%2F%2Fexample.net%3A8080%2Fiiq%2Fscim%2Fv2%2FEntitlements%3Ffilter%3Dapplication.displayName%20eq%20%22OKTA%22
but still getting the same error
Claire Berry
I eventually got it working with what you suggested, think I miss-typed something the first time. Thanks @Fabio Racobaldo _Herzum_
Like • Fabio Racobaldo _Herzum_ likes this
you're welcome @Claire Berry
SERVER
