Integration between Jira x ZenDesk
Felipe Dorocinski October 22, 2020
I would ask you a question... I read some documentation about this integration and there was written that you can create a jira issue from Zendesk, but nothing about the opposite. I mean, our idea is connect our financial team with our costumer support area, creating a zendesk ticket requesting some documents, etc. However, as i said before, reading all of the documentation i've found, i could not see this workflow.
So, do you know if it is possible?
Jose Lobo (Solutions Architect at Exalate)
October 22, 2020
Hello @Felipe Dorocinski
Jira - Zendesk native integration is really good for basic integration scenarios.
There will be an interface on the right side of the Jira issue that shows you to change fields of the ticket copy of the Zendesk side
I am not sure if bi-directional integration is supported. However, I recommend you check Exalate if you are still looking for:
  • Flexibility: A tool that allows you to integrate bi-directionally with field mapping (both ways)
  • Comment impersonation: See the username of who commented from the other end
  • Multiple nodes: Connect more than 2 instances if needed in the future
Let me know if this helps!
Jillian Amyot _Unito_
Alternatively, you could create the integration using Unito. You would create the "flow" starting from Zendesk, to Jira. It would also have the information flow both ways if you needed, so its more dynamic than automating it. Here's a link that might explain more. Hope this helps!
Support - Leoj Studio
Yea, it sure is possible
but you have to integrate it by your self,
the best way to integrate is using Zapier
and workflows are not needed,
If any help needed with zapier just ask
Thanks for answering @Support - Leoj Studio
However, im trying to do this integration using "Zendesk Support for Jira integration", principally because, i might be wrong, but Zapier has an autommation which isn't much flexible. Here, we'll need to create this zendesk ticket only in specific situations, and as i could understand, zapier is gonna create this ticket always when we insert a comment or something like this.
