Is it possible to get transition dates using script runner?
Rob B
November 21, 2017
I need to get the date of certain transitions in certain issues. We are currently manually going into each issue to get the dates.
Thanos Batagiannis [Adaptavist]
November 21, 2017
Hey Robert
When you say certain issues I suppose issues that you can get from a JQL ?
Also you say the date of certain transitions does this means the first time that the issues got into that transition ?
Rob B
November 21, 2017
Hi Thanos,
Yes we run some JQL to export our SLA data, but we manually add a column for transition dates and we get these by manually going into each call. This is basically so we know when the SLA starts.
Example...
November 21, 2017
Hey Robert,
So what about using a scripted field that will show you the date of first transition, and then since you will have this value in a field you will be able to export it in the same way as any other field.
How does this sound ?
Rob B
November 21, 2017
Where do i declare what issuetype we are reporting?
(eg. issuetype=BILL01 and status=Review)
Sorry about this but im a beginner to this. Thanks
November 21, 2017
Which version of ScriptRunner you use ?
If you are in one of the latest versions there is already a canned scripted field Date of First Transition.
Rob B
November 21, 2017
Unfortunately we are only using version 4.3.19, but we are doing an upgrade next year. Finally!
November 21, 2017
Hey Robert,
No worries. So you have to create the scripted field manually. It is easy. So go to the scripted fields section and add a new one.
The script for this should be
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def created = changeHistoryManager.getChangeItemsForField(issue, "status").find {
it.toString == "In Progress"
}?.getCreated()
def createdTime = created?.getTime()
createdTime ? new Date(createdTime) : null
And the configuration should be
Searcher: Date Time Range picker
Template: Date Time Picker
In the end your scripted field should look like
Screen Shot 2017-11-21 at 15.02.20.png And then you can start using it as any other custom field.
Please let me know how this went.
Regards, Thanos
Like • 4 people like this
Rob B
November 22, 2017
The field created with the correct data! Cheers Thanos!
Would i need to create a new one for every transition an SLA starts on? For example we have 3 SLAs on one workflows which all start on different statutes.
Rob B
November 23, 2017
Do i need to log that as another question?
November 23, 2017
Hey Robert,
No it's all right, I just missed the reply. Can you please give me an example or use case for your second question ?
Regards, Thanos
Rob B
November 23, 2017
The users are running a report about SLAs which captures the usual, but they want the start date of the SLA (hence creating the script field), but some issues have more than one SLA, so does this mean have a different script field for each status (start of SLA).
Rob B
November 27, 2017
I hope that makes sense?
shiva November 19, 2020
@Thanos Batagiannis [Adaptavist]
How do i get date of the last transition status.
Register now 🚀
