Is there a way to hidden portal field based on organisation?
Kuen Gnee Seah March 23, 2018
We have a few organisation. Some are internal and some are external. Is there a way where the portal field is visible or hidden based on reported in the organisation ?
Susan Hauth _Jira Queen_
If you are on Server, then add-on: Extension for Service Desk may be able to help with that.
Susan
Kuen Gnee Seah March 25, 2018
Hi Susan,
Thank for the suggestion. However, currently Service desk is on three agents license but Jira on 100 users. So might be costly
Seah Kuen Gnee
Deleted user March 23, 2018
Hi @Kuen Gnee Seah,
Just to confirm, you would like it so a field is hidden if a customer from organisation A creates an issue, and the same field is visible if a customer from organisation B creates an issue?
I do not think this is possible as it is not referred to in the documentation. My suggestion would be to copy the original Service Desk Project and transfer organisation B over to the new Service Desk Project. You could configure the field visibility for that particular organisation.
 Hope this helps.
Hi Danny,
Is troublesome for support team to monitor two projects. Is there alternative? Reason is I have a client field which allow internal organisation to view only.
Learn more
