×Issue Links section is not showing in JSD. Might be due to a configuration done by our initial provider but I am unable to find where this is done. We do have a custom link that does show using an addon called Issue Matrix.
Hi Ivan,
Thanks for pointing out that you do have Issue Matrix. This helps a lot.
Can you please check the screen that this issue is using? There is likely a matrix custom field on it, noting there may be more than one.
For the custom field, you can then adjust its configuration to display all links (or perhaps just relates to, as you've got above). Issue Matrix does this to avoid displaying links twice - you have full control over what displays with Issue Matrix.
Read more here: https://botronsoft.atlassian.net/wiki/spaces/ILV/pages/1130758212/Issue+Links+Mode
Let us know how you get along.
