JQL for issue with approvals null
Josip Šćirek November 9, 2017
How I can filter issues that don't have approvals? field empty (No approvers selected).
Jack Brickey
November 9, 2017 edited
@MoroSystems Support, the "is" operator is not supported for Approvals field.
@Josip Šćirek, the only thing I can suggest right off is to use the "pending()". If I find a better solution I will add here.
MoroSystems Support
November 9, 2017
@Jack Brickey thanks for correction, it slipped out of my mind.
Josip Šćirek November 13, 2017
@Jack Brickey Thx for information but "pending()" is not what i need.
Andrey Ivanov
Hello, in order to find the tickets that:
* are "Resolved" and "Closed"
* are NOT "Pending" or "Waiting for approval"
* doesn't matter have or have not approvers
* were NOT approved no matter how
No suggested option suits my case.
I have this JQL:
project = PROJ AND ("Approvals[Approvals]" = approved()) AND key in ("PROJ-123", "PROJ-456") order by created DESC
And it returns 1 ticket PROJ-123 which was approved, and is closed and resolved and etc.
I have also these JQLs:
project = PROJ AND NOT ("Approvals[Approvals]" = approved()) AND key in ("PROJ-123", "PROJ-456") order by created DESC
project = PROJ AND (NOT "Approvals[Approvals]" = approved()) AND key in ("PROJ-123", "PROJ-456") order by created DESC
project = PROJ AND !("Approvals[Approvals]" = approved()) AND key in ("PROJ-123", "PROJ-456") order by created DESC
project = PROJ AND (!"Approvals[Approvals]" = approved()) AND key in ("PROJ-123", "PROJ-456") order by created DESC
Not only neither of them work properly (returning PROJ-456), some of them return the same APPROVED PROJ-123 which is absolutely irrational and unbelievable.
Sean Roberts June 12, 2020
For this, we use the 'approvers' field in JQL.
Problem: However, by default the field is not searchable, which is why it does not work in JQL.
Solution: A Jira admin can update the custom field to be "searchable". It may require reindexing.
BUT, I agree that `approvals()` should have other functions, such as != or `is not`.
For example, I would like to search for items which have `approvers` but have not been approved. Checking `approval=pending()` is not enough since that only accounts for ones where the current status is an approval status.
And this doesn't work:
  • and not approvals = approved()
You get the same result with 'and' or 'and not'.
Richard November 6, 2019
Maybe you can try Approvers (field) instead of Approval (function).
Something like this works on our instance:
status = "Awaiting approval" and Approvers in (EMPTY)
Note 1: "Awaiting approval" is the status of your workflow where the "Approvers" are set.
Note 2: The "Approvers" field is available when "Service Desk" is installed.
Cheers!
Martin Böhme
I have Jira Service Desk Cloud and there is no "Approvers" in JQL.
In order to search for a certain approver, you need to query
Approvals = approver("username")
And this way, you can't search for an empty Approver field. Or at least, I don't know how :(
Richard May 19, 2020
Have you tried adding this to your JQL query?
and approver in (EMPTY)
MoroSystems Support
November 9, 2017
Hello Josip,
I think you ar looking for "is EMPTY". Please, try this JQL:
status = "Awaiting approval" AND Approvals is EMPTY
Josip Šćirek December 15, 2017
I get message:
The operator 'is' is not supported by the 'Approvals' field. Unknown Approval function. Please use one of supported functions: pending, pendingBy, approved, approver, myApproval, myPending
Like • Justin Warwick likes this
Dean Zimmermann
Yes, same here.  They really need something to indicate approvers is empty, like maybe just isempty() or approvercount() = 0
Like • 2 people like this
