Hi Everyone,
JSM DC: Cascading issue on custom fields (cascading by scripting Scriptrunner)
I am facing two issues while cascading through scriptrunner on 2 custom fields.
customfiled B depends on customfield A
1. Performance issue(takes few seconds 2 cascade or appear list on customfield B)
2. While changing options on customfield A, the old value on customfield not automatically removes.
Thanks in advance
To report the value of a cascading field (field 2) with the value of another cascading field (field 1) in Jira Cloud Automation, you can use the following sequence of actions:
jsonCopy code
"fields": {
"customfield_FIELD2":
{"value": "{{issue.fields.customfield_FIELD1.value}}",
"child": "{{issue.fields.customfield_FIELD1.child.value}}"
Replace "field1" and "field2" with the names of the custom cascade fields you created. This code sets the value of the cascade 1 field to the value of the cascade 2 field. Note that the value of "child" is optional, depending on whether or not your cascade field has child options.
To use this code in Jira Cloud Automation, follow these steps:
With these steps, you will have set up your automation to report the value of one cascading field with the value of another cascading field.
