I upgraded JIRA from 8.22 to 9.0
Unfortunately after update add-on Jira Automation doesnt work.
After enabling im getting error: "This app failed to enable. Refer to the logs for more information."
I tried:
- Reinstall app
- I purged tables:
delete from "AO_589059_AUTOMATION_QUEUE";
delete from "AO_589059_AUDIT_ITEM_PROJECT";
delete from "AO_589059_AUDIT_ITEM_ASC_ITEM";
delete from "AO_589059_AUDIT_ITEM_CGE_ITEM";
delete from "AO_589059_AUDIT_ITEM_COMP_CGE";
delete from "AO_589059_AUDIT_ITEM";
anything doesnt work.
Any idea to re-enable plugin after upgrade ?
I tried to purge tables:
@IT Admin Welcome to the Atlassian community
Did you follow all the steps here: https://confluence.atlassian.com/automation/upgrading-to-automation-for-jira-7-3-or-later-1055951956.html
There is more to do then just delete tables. If that does not work what are you seeing as the errors in the logs?
Will this mean that we lose all logs for the automation rules?
In the wake of growing customer expectations, development teams are facing more pressure to deliver innovations faster. Register for this 45-minute webinar to learn how devs can accelerate software delivery and time-to-market with Jira Service Management.
Register now 🚀Online forums and learning are now in one easy-to-use experience.
