Jira character encoding
Gleb Kartashov
January 19, 2020 edited
Hi! I have a problem with Jira character encoding. I have a Groovy code which is used to execute POST request to my server app (Express.js) and recieved data has question mark symbols instead of cyrrillic characters.
This is what characters look like from Jira:
Groovy code:
import groovyx.net.http.HTTPBuilder;
import static groovyx.net.http.ContentType.*;
import groovyx.net.http.ContentType;
import static groovyx.net.http.Method.*;
def http = new HTTPBuilder('myhost.com')
http.request( POST ) {
uri.path = '/'
requestContentType = ContentType.JSON
body = [title: issue.get("summary"), desc: issue.get("description")]
log.info(body.title)
response.success = { resp ->
log.info( "POST response status: "+resp.statusLine+"}")
 Server app code (Express.js)
app.post('/',(req,res) => {
res.send('test');
console.log('post in');
//console.dir(req.charset);
console.dir(req.body);
Database character encoding is UTF8 and chartype is Russian_Russia.1251
Jira character encoding is "Cp1252" and I dont know how to change this. If somebody could explaing how to do this it would be great.
Also I asked this question couple of weeks before and I've been told that problem is on my server app side https://community.atlassian.com/t5/Jira-Service-Desk-questions/Character-encoding-with-HTTPBuilder/qaq-p/1250738
But on the same Jira server I'm using Insight Automation tool to post data to Confluence server and those characters also are corrupted
Jira and Confluence databases use same config (as described above)
Adrian Stephen
January 20, 2020
Hi @Gleb Kartashov
To resolve this issue, please follow the steps from:
https://confluence.atlassian.com/jirakb/jira-application-internationalisation-and-encoding-troubleshooting-203394762.html
  1. Stop JIRA
  2. Follow the steps from this page: https://confluence.atlassian.com/adminjiraserver070/setting-properties-and-options-on-startup-749383528.html
  3. From /bin, open setenv.sh. Find the section JVM_SUPPORT_RECOMMENDED_ARGS=
  4. Add the following arguments in that section JVM_SUPPORT_RECOMMENDED_ARGS="-Dfile.encoding=utf-8 -Dsun.jnu.encoding=UTF-8"
  5. Save that file=
  6. Restart the application and verify if the issue is fixed
