Jira had problems starting up
JiraYo
March 16, 2020
My server restarted last night and now jira wont start. I dont want to have to restore from backup, as i dont know even if that will solve the problem. The error is "we couldn't start the following plugins", and the full text of the error is below.
I had recently 2 weeks ago, updated to JSD 4.7.1 and the latest jira core at the time (march 3rd). I guess i will call support and see what they say.
 ___ Starting the JIRA Plugin System _________________
2020-03-16 07:55:44,599-0700 JIRA-Bootstrap ERROR [c.a.jira.startup.SystemPluginsEnabledHealthCheck] We couldn't start the following plugins:
- Jira Projects Plugin (com.atlassian.jira.jira-projects-plugin)
- Atlassian Jira - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
- Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
- Gadget Directory Plugin (com.atlassian.gadgets.directory)
- Atlassian Jira - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
- Atlassian Jira - Plugins - Global Issue Navigator (com.atlassian.jira.jira-issue-nav-plugin)
- Atlassian Pretty URLs Plugin (com.atlassian.prettyurls.atlassian-pretty-urls-plugin)
- Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
- Atlassian Jira - Plugins - REST Plugin (com.atlassian.jira.rest)
- Opensocial Plugin (com.atlassian.gadgets.opensocial)
- Gadget Spec Publisher Plugin (com.atlassian.gadgets.publisher)
- Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
- Static Assets (CDN) Plugin (com.atlassian.plugins.static-assets-url)
2020-03-16 07:55:45,646-0700 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2020-03-16 07:55:45,646-0700 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2020-03-16 07:55:45,646-0700 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2020-03-16 07:55:47,803-0700 JIRA-Bootstrap ERROR [c.a.jira.startup.DefaultJiraLauncher] JIRA has failed to start because of the following errors: [(Event: Level = (EventLevel: fatal) , Key = (EventType: system-plugins) , Desc = We haven't been able to start all the required system plugins , Exception = We couldn't start the following plugins:<br/><ul><li>Jira Projects Plugin (com.atlassian.jira.jira-projects-plugin)</li><li>Atlassian Jira - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)</li><li>Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)</li><li>Gadget Directory Plugin (com.atlassian.gadgets.directory)</li><li>Atlassian Jira - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)</li><li>Atlassian Jira - Plugins - Global Issue Navigator (com.atlassian.jira.jira-issue-nav-plugin)</li><li>Atlassian Pretty URLs Plugin (com.atlassian.prettyurls.atlassian-pretty-urls-plugin)</li><li>Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)</li><li>Atlassian Jira - Plugins - REST Plugin (com.atlassian.jira.rest)</li><li>Opensocial Plugin (com.atlassian.gadgets.opensocial)</li><li>Gadget Spec Publisher Plugin (com.atlassian.gadgets.publisher)</li><li>Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)</li><li>Static Assets (CDN) Plugin (com.atlassian.plugins.static-assets-url)</li></ul>)]
2020-03-16 07:55:47,803-0700 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 727 MiB. Committed: 2604 MiB. Max: 3942 MiB
Non-heap memory : Used: 263 MiB. Committed: 282 MiB. Max: 1536 MiB
TOTAL : Used: 990 MiB. Committed: 2885 MiB. Max: 5478 MiB
JiraYo
March 16, 2020
i cleared the logs directory at \\jira\c$\Program Files\Atlassian\JIRA\logs and then restarted again to generate clean logs i could pick through.
jira then started fine like nothing was wrong at all! weird man weird....
JiraYo
March 16, 2020
ah it looks like the plugin insight is no longer working.. hmm
