Hi all!
Help me solve the problem please.
I'm setting up automation.
Related task:
When an author or approver writes a comment to a task via mail or portal, and the task status was “Closed,” the ticket is reopened, the status changes to “Reopened,” and a comment is sent to the parent task about the re-opening of the related task.
What is the problem :
I don't know how to specify a smart value in automation for a specific related task that has changed since there can be multiple related tasks.
I tried a lot, for example, if you use {{issuelinks}}, then in the comments there will be links to all related issues, but I need a specific one.
Please tell me the solution.
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →Online forums and learning are now in one easy-to-use experience.
