Pie charts using the same colors
Paul Prata May 20, 2024
I have several pie charts to show open / closed tickets and would like to have the charts us ethe same colors, but I do not see this option.
Mikael Sandberg
May 20, 2024
You would need an app in order to do this, the default gadgets in Jira do not allow you to configure the colors. There are multiple apps in the Marketplace that can do this. We use Custom Charts and one of the reasons we selected it was the possibility to configure the chart colors.
Laurie Sciutti
May 21, 2024
I second this for Custom Charts!
Like Mikael Sandberg likes this
Paul Prata June 11, 2024
Thank you for the information, I will look into this. Is there a data limitation on showing the # of records? Some I have tested only bring 2500 records?
Mikael Sandberg
June 11, 2024
@Paul Prata Custom charts I think have a 20000 limit so your 2500 records should be fine.
Ivan Garcia {Appfire}
Hi @Paul Prata
Our own Dashboard Hub Pro is also a great option to customize your pie charts :)
Select your preferred colors, show/hide and move segments to set it your way.
In this example 👇 I selected the actual colors of Jira statuses to improve semantics.
I have leveraged this and does allow me to control the colors, but only brings back 2500 records. There is an issue with this and a fix but no ETA on the release of the fix.
