Pop comments window when changing issue workflow
Nick Dring
Hi there, I wanted to know how I go about adding a pop-up window for comments when a JSD agent changes the workflow status.
At the moment an agent would add a comment informing the colleague that their request has been done and we are awaiting their approval. So the steps an agent would take are:
  • Click on the comment field
  • write the comment
  • click on share
  • go change the status by selecting Waiting for Approval in the Workflow drop down.
The colleague would receiver two email notifications, the comment and the status change.
I want to change the steps so that the agent would
  • change the status by selecting Waiting for Approval in the Workflow drop-down (which brings a pop-up window where the agent can add comments)
  • agent writes comments
  • click on share
Now the status changes and one email goes out to the colleague with both the comment and the approval request button.
Thanks in advance for any help :)
Marco Brundel
April 21, 2021
Hi @Nick Dring ,
You can map a screen to a transition. See https://confluence.atlassian.com/jirakb/map-a-screen-to-a-workflow-transition-in-jira-server-720634253.html
When you create screen without fields the only thing that is shown is the comment.
See https://confluence.atlassian.com/jirakb/how-to-add-a-comment-during-a-transition-779160682.html
Is this what you are looking for?
Regards Marco
Nick Dring
Marco that is exactly what I was looking for, thanks!
Screen mapped to transition :)
Cheers
Nick
Like Marco Brundel likes this
SERVER
atlassian, atlassian community, journeys for jira service management, journeys for jsm, eap jsm atlassian, early access program atlassian, early access program journeys atlassian, early access program journeys jira service management, join atlassian eap
Join the Early Access Program (EAP) - Journeys for Jira Service Management 🚪
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →
