ProForma is disabled for some projects
Nic October 26, 2021 edited
We are trying to evaluate ProForma for use in our Cloud installation.
On the configuration page, I have selected enabled Projects: Enable By Default, and enabled Performa for all of our projects.
However, on the Forms page,  form creation is only enabled for a handful of our projects:
We would like to enable form creation on all projects.  How do we make this happen?
Fabian Lim
October 26, 2021
Hi @Nic ,
I would contact pro forma directly for a faster response.  Maybe there is a hidden setting somewhere.
Link: https://marketplace.atlassian.com/apps/1215833/proforma-forms-checklist-for-jira?tab=support&hosting=cloud
ProForma is owned by Atlassian, so their support link lands here.
Fabian Lim
October 26, 2021
Oh yes, I forgot that they were acquired.
One question, what kind of form are you adding that you need it for every project? The reason I ask is that it affects performance because the issue will load the proforma sections by default.
Nic October 27, 2021
We do not want it on every project, in reality.  However, we *should* be able to configure it that way and have it work.
Peter Preston
October 27, 2021
@Nic - this looks like it might be a permissions issue. Have a look at the ProForma permissions troubleshooting page here:
http://links.thinktilt.net/troubleshoot-permissions
Let me know if that helps. If not, we can work through it.
Like • Fabian Lim likes this
Nic October 28, 2021
@Peter Preston thanks, I'll take a look at this.
It was indeed a permissions problem.
You need to be a project administrator for the given project.  Being as site admin does not grant access.   @Peter Preston thanks for the help.
Like • 2 people like this
atlassian, atlassian community, journeys for jira service management, journeys for jsm, eap jsm atlassian, early access program atlassian, early access program journeys atlassian, early access program journeys jira service management, join atlassian eap
Join the Early Access Program (EAP) - Journeys for Jira Service Management 🚪
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →
