Hello team,
I'm a member of Exalate add-on development team.
Recently our customers started to report a bug about when Exalate creates issues in Jira Service Desk (Server) then SLA fields are empty. Creating issues manually by users is OK.
Exalate is utilizing Java API to create issues programmatically.
Could you please advise ?
Hi @[deleted] ,
Perhaps you should try and contact Exalate Jira Issue Sync & more plugin vendor directly trough support channels. Whereas, in the meantime inform what is the Jira version you are running and Exalate Jira Issue Sync & more plugin version installed, so other using the place versions could contribute to this thread.
Rafael
Hi @Rafael Pinto Sperafico
Thanks for you reply !
Actually I'm a member of Exalate dev team and post this request on behalf a team :)
Jira Server 8.0.0 / Jira Service Desk 4.0.0
Exalate 4.6.1 (latest)
Hi @[deleted] ,
Thank you for your update.
Here is what I would suggest:
Once you have the 2 payload, you can compare them looking for any missing attribute.
Looking forward to hearing back from you.
Rafael
