Service Desk Help Center redirect problem
Jonathan Churchman September 4, 2017
We use Cloud versions of Confluence, JIRA and JIRA service desk. The latter is for a specific business area, but appears to be impacting more broadly.
Ever since implementing the Service Desk, whenever a new user is created (even if only allowed Confluence access), when they register their password and click OK they get redirected to the Help Center portal for the Service Desk. There are no links to take them back to the home or to any other areas they might have access.
Previous responses from Atlassian have been that they are Service Desk users because they have emailed the service desk at some point, but many of these have never done so.
Any ideas on why this is happening or whether I can do anything about this would be gratefully received.
Justin Denley
April 12, 2018
Experiencing same issue, any progress updates?
Shannon S
April 12, 2018
Justin,
If you're running into the bug CONFCLOUD-55961 then it appears to still be an open bug that we are working on.
Please vote on that bug to help show the number of users who are running into the issue. If you watch the case, you'll be updated of any progress.
Thank you!
Shannon
Justin Denley
April 12, 2018
Ok, understood and thank you
Martin Heyder
February 6, 2019
Shannon,
We're having this same issue. Has the bug really not been resolved yet?
-Martin
Shannon S
February 6, 2019
Hi Martin,
This issue has been closed, and it appears now Confluence end is fixed, but there's still an issue in the Jira side. An Atlassian ID case was opened below:
  • ID-6349 Some users with access to only Confluence are not being redirected to Confluence
Per the comment from the developers on the Confluence case, if you're impacted by this bug, you may want to work around this issue for your users by setting the default home page as described here:
Shannon
Martin Heyder
February 6, 2019
Hi Shannon,
The workaround article you reference does not reflect the current UI. There is no option to set the default homepage under the Site Administration ->Product Access section. If you've moved this, please direct me to the current location.
-Martin
Shannon S
February 7, 2019
Martin,
Thank you for letting me know. I compared it to my instance, and I see that if you have the new User Management. I've investigated this, and it appears that the feature is being actively developed for the new User Management. I have submitted a feature request to correct the documentation:
  • ID-6749 Set your site homepage documentation no longer relevant
At this time, it doesn't appear that there is a workaround for your situation, but I would watch both the new bug I sent you, and the documentation request.
Shannon
Mark Keane October 11, 2017
Hi Jonathan I have just noticed we are experiencing the same issue as you and we have the same applications. Shannon mention previously that it is "not possible to change the email content"(was she speaking about the invitation email?) because you are able to add content to the "Invite Message" textbox in the invitation email see screenshot.New_User.png
Also another work around for the new users that are redirected to the Customer Portal is to add announcement to the your Service Desk Customer Portal. Please see screenshot of our Customer Portal. Service_Desk_Landing_Page.png
This bug was reported at the end of May is there any update on this issue @Shannon S? Like Jonathan said this creates a poor UX for new users, our users are our customers and it isn't good enough for this issue to still persist.
Shannon S
October 11, 2017
Hi Mark,
The screen you found is to add additional details when inviting a Jira user to the instance, but the original question was to change the URL that's included in the invitation email for Service Desk Customers.
There's no update at the moment as far as I'm able to tell on that bug ticket, but please do watch it and leave your feedback there as our development team will be able to reply directly on that case.
Kind Regards,
Shannon
Hi Shannon ok I see thanks for shedding some light on the original Q, you can add a note and the URL to the confluence space to inform the user with "invite Message" field. I find the best workaround is to have links to the applications in the customer portal as well. Very disappointing to say the least that there is no update on this, over the past year or two any bugs or issues I have encountered with Atlassian products the majority of them have not been resolved. I always leave feedback but it seems pointless at this stage.
Shannon S
October 11, 2017
Mark,
Sorry - I mispoke earlier when I mentioned Jira and Service Desk - I meant to say for Confluence-only users. However, the point is that you can't edit the URL being sent automatically, but you can include a note in the invite email as you discovered to use the other URL.
I've mentioned the team internally on the bug so hopefully we can get more information on this case and its place in our future roadmap. Please keep an eye on the bug since the updates will be placed there.
Kind Regards,
Shannon
Thanks Shannon
Jonathan Churchman October 11, 2017
Hi Shannon, I didn't know you could add links or announcements on the Customer Portal page.  That looks like it could provide a decent workaround.  I'll have to figure out how to do that.
Jonathan
Shannon S
October 11, 2017
Hi Jonathan,
I checked; when you add an announcement, it's added to a specific portal.
So you'll need to edit the Customer Permissions and make sure to set Anyone with an account on https://[yourURL].atlassian.net to this permission.
Otherwise, if a Confluence user tries to access the instance, gets redirected to portal and hasn't been given access, they won't see the announcement. Here's what my Confluence-only user sees before I set the permission:
And here's they see once I set it:
Screen Shot 2017-10-11 at 4.52.33 PM.png You can see the announcement I set there at the top.
I hope this helps! Let me know if you have any trouble.
Kind Regards,
Shannon
Shannon S
September 5, 2017 edited
Hi Jonathan,
We do have a current bug that states Confluence-only users are being directed to the Customer Portal in JIRA Service Desk:
Can you confirm if this is what is occurring for you, or if JIRA+Confluence users are having the same issue?
Kind Regards,
Shannon
Jonathan Churchman September 5, 2017
It's quite similar to the bug mentioned, in that when users login for the first time they are directed to the JIRA Service Desk portal.  Although the workaround wouldn't work, as there is no "Application Navigator" on the page to take them back to Confluence.
What I have to do is send a follow up email directly to the user with a link to <instance-name>.atlassian.net
This appears to be very similar to the comments from users in the ticket.
Shannon S
September 7, 2017
Hi Jonathan,
Both JIRA and Confluence are on Cloud, correct? Do they not share the same <instance-name>.atlassian.net?
If you ordered them separately and they do not share the same URL, then you can still link them together in Application Links and have Confluence appear in the JIRA Application Navigator. This will be generally displayed in the form of a "hamburger menu" which is three parallel lines on top of one another.
Are you able to provide me a screenshot of what you're seeing so I can direct you to the right location?
Kind Regards,
Shannon
Jonathan Churchman September 7, 2017
Hi Shannon,
Yes, they share the same instance name and during normal operation you can flick between Confluence and JIRA using the hamburger menu.  The issue, as you can hopefully see from the screenshot is that the user has no option to link to anything.
Any advice would be great.
Jonathan
Shannon S
September 7, 2017
Jonathan,
In that case, I would recommend to tell them to go straight to <instance-name>.atlassian.net/wiki, and they will arrive at Confluence.
Let us know if they can access directly from that link.
Kind Regards,
Shannon
But that is what we do, as a workaround, by sending each user a separate email with a link to <instance-name>.atlassian.net/wiki
They can access that link, as it is not a permission problem.
The point is that ever since we rolled out the JIRA Service desk, when a brand new Confluence user gets the welcome email and goes to add a password, they get that Customer Portal screen next, rather than going to the Confluence home.
It didn't happen before we had the Service Desk and it's a poor user experience.
Shannon S
September 7, 2017
Jonathan,
Thank you for your feedback. Indeed this is the same bug and we are working on a solution for it, so in the meantime, your users will need to use the /wiki URL.
Since it's not possible to change the email content, you will want to contact the users directly to let them know how they can access Confluence.
Kind Regards,
Shannon
As I mentioned earlier that is what we already do.
Shannon S
September 7, 2017
Jonathan,
Thank you! I understood that is what you are currently doing; you will need to continue that practice until the bug is resolved. Thank you for your understanding!
Take care and Kind Regards,
Shannon
