Sign up Log in
Setting Up Bitbucket Pipelines for Flutter Android Application
Karpaga Selvan September 27, 2024
Hello Atlassian Community,
I am currently working on setting up Bitbucket Pipelines for a Flutter project. I have some experience with CI/CD but am relatively new to configuring pipelines for Flutter applications.
My Question:
Can Bitbucket Pipelines handle the Flutter environment, or do I need to set up a custom Docker image? If so, what is the best approach to ensure that the necessary Flutter SDK and dependencies are available during the build and test stages?
Current Setup (Under Planning):
Here is the basic configuration I'm planning.,
Additional Context:
  • I am using Bitbucket for version control and Jira for project management.
  • My project involves a mobile application built with Flutter.
  • I have experience with Selenium, BDD Cucumber, TestNG, and Postman for API testing.
Any advice or best practices for setting up Bitbucket Pipelines for Flutter would be greatly appreciated!
Thank you in advance for your help.
Best regards,
Karpaga Selvan M.
atlassian, atlassian community, journeys for jira service management, journeys for jsm, eap jsm atlassian, early access program atlassian, early access program journeys atlassian, early access program journeys jira service management, join atlassian eap
Join the Early Access Program (EAP) - Journeys for Jira Service Management 🚪
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →
Upcoming Jira Service Management Events
