Hi ,
I would like to change the default value that gets selected on system field "Priority".
I did not find any way to do this.I want to set some common value as the default priority in create/edit but/story and other screens. Can you please help me with that?
Go to Issues -> Priority Schemes. Find your scheme and click Edit. There will be the Default Priority field, where you can choose the default priority for the Priority Scheme.
Thanks for responding. This actually does not work for me and when I set the default, I get a message that this action cannot be done. The Jira team has mentioned to me in another thread that setting defaults is not supported for system fields and I need to do something else for this like use plugins etc.
@Prashanti Bharathwaj Hi. How did you solve this problem? I also want to fill default value into the field when I click the toolbar menus such as 'create / edit'
I want to change the default priority from Highest to Medium. This seems like a simple and obvious things to want to do. But here I am 15 minutes later tearing my hair out working through the totally convoluted Jira administration system with no ideas. I've read other threads on this topic which point to various non-existent menu options as Atlassian has likely shuffled the deck chairs repeatedly over the last few years. Is this possible?
I missed your earlier message and did not respond. We just created a "new priority scheme" and made the priority we wanted as default and attached it to projects. We did not use the "default priority scheme" because of this reason of not being able to edit as I mentioned in my earlier comment.
I also faced another trouble with incoming mail handlers creating issues with a different priority and I used the solution specified here. https://jira.atlassian.com/browse/JRASERVER-67511
I reordered the fields in such a way that the default priority I wanted is the middle one.
We are on Jira server 7.13.5 currently.
@Randall Eike , please check if one of these solutions resolve the issue for you.
@Tengfei_Liu Thanks for your response. I was looking for "Priority Schemes" but it is under just "Priorities."
For anyone else stumbling on this:
Settings ==> Issue Attributes ==> Priorities
-Randall
@Prashanti Bharathwaj i need to change the value of priority to character set instead of number how i can do this please?
i use liferay portal 7.0
How to set up a default option for the priority field for one issue type and rest are editable for users in case of other issue types.
exmpl: For Incident issuetype priority should be auto popuated as P1 and for other than this issue type priority can be editable by user.
Please help in this.
Thanks.
Chandra
Did you find how to do this?
How to get the priority value to change according to the issue type selected on the create screen.
For example, When the issue type is chosen as Story and then the priority should be populated high.
Melik
Hi All,
I am trying to follow the instruction on this chain to update my default priority level for my project but it is not working. I am not seeing a priority Scheme anything on the tool. Please help thanks!
Seems to be a global setting for all Projects? and not a per project setting, Which is another pitfall?
Dears,
Hi
Based on attached image, the default priority change to LOW and I want to revert Medium same before, but I don't have access to edit button here.
I would be grateful to guide me add edit by dark mode feature.
Why is this so Hard? I spent an entire morning working this out. How about a KB article "How to change he default priority". Yikes...
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →Online forums and learning are now in one easy-to-use experience.
