I'm using JMWE app's Transition current issue post function and it gives me "An error occurred while executing a Transition Current Issue post-function: Validation error while triggering transition [381@@RQ: Default Workflow]: root cause: Validation error"
This transition doesn't have any validators.
In the follow-up transition there's a Set field value post function. When I turn it off (set condition to false) issue transitions fine. In the Set field value post function I'm populating a Multi user picker field. Value is array list of user keys (string). Do I have to use a different value for this? ApplicationUser or maybe string is fine and I need usernames for this field?
Hi @Gleb Kartashov ,
the "Validation error while triggering transition" error is a little misleading. Jira doesn't differentiate between errors during validation and errors during execution of the transition.
In your case, it seems that the problem is with one of the post-functions on the triggered transition, which makes the transition fail, hence making the Transition Current Issue post-function fail.
In your Set FIeld Value post-function, check the "expected value" help tab. The values need to be usernames, not user keys. Or of course ApplicationUser objects if you prefer. The reason is two fold:
