Transition is not visible in portal
Andrej Freeze _ greenique
February 12, 2018
Hello everyone,
I was trying to display a transition in the customer portal, but it just does not appear there.
I checked the following screws that might be responsible:
  • Permission of customers to trigger a transition
  • Visibility of both statuses within the customer portal
  • Checkbox Display in customer portal for the transition is checked
  • Transition does not contain any conditions
Does anyone have an idea what I missed out on?
Versions are JSD 3.8.1 and Jira 7.5 in case that might help.
Thanks in advance
Jack Brickey
February 15, 2018
@Andrej Freeze _ greenique can you get any transition to work? The most common ones are Reopen and Resolve. Can you provide a screenshot of what you do see on portal?
Brittany Wispell
February 14, 2018
Hi @Andrej Freeze _ greenique
Did you add the resolution after clicking the checkbox then 'Publish' the workflow?
You'll be looking for Text rather than an actual button.
Hope you've found a solution already!
February 14, 2018
Hey Brittany and thank you for your answer.
I'm afraid I have done so, and was not yet able to find a solution.
As soon as I do I will make sure to post it here.
