Xray - Auto populate fields in Create screen with data from a Linked Issue?
reuben.hollifield
We are using the X-ray App to run our Quality Assurance and Testing department.
In the Xray app, you have the option to create a Defect issue straight from a Test case execution.  I would like to auto fill certain fields in the Defect with data that is already in the Test case execution.
In particular, I'd like to populate a custom field with a list of the "steps" that are detailed in the Test case.
Here's what I'd like to do:
  • User initiates Test Execution for the Test.
  • User encounters a Defect and clicks the "Create Defect" button in the Execution itself.
  • The Create screen appears for the Defect issue type (Jira automatically Links the Test issue to the Defect Issue already).
  • We would like Jira to automatically populate a field within the Defect's Create screen with the steps that are indicated in the Test.
Is this something that can be done through the API?  I'm not familiar with programming, at all, but wondering if this is possible.
José Domingues _Xray_
Hi Reuben,
There is an Xray configuration that enables that option, to activate it you must access the "Add-on" tab on your Jira Administration Tools, go to the "Miscellaneous" window under the "Xray" section and travel to the "Defect Default Values" area:
There you can enable the "Include Steps Table in Description" like it is shown on the image above.
Hope this helps!
Best Regards,
Team Xray.
Manisha Minde September 22, 2020
Hey Jose,
Is it possible to add bug template whenever we create bug ticket? Like in above question if I want to add some default text I have with me (say description, browser version etc.) Can I do that?
@José Domingues _Xray_
Sergio Freire - Xblend
October 19, 2020
@Manisha Minde
No, currently, only the Test Steps are copied over to the New Defect if the mentioned option is enabled. No other fields are passed along, nor any extra data.
Best Regards,
Sérgio
______
Solution Architect and Testing Advocate @Xray
Personal blog on testing, Agile and software development: https://sergiofreire.com
Follow me on Twitter: https://twitter.com/darktelecom
Sneha Kumari
Is the option "Defect Default Values" available in cloud instance also? Because I am not able to find the particular option under "Miscellaneous" section.
Rogério Paiva - Xray Xporter
March 26, 2021
Hi @Sneha Kumari
Due to the architecture limitation currently, it is impossible to have that option working on Xray Cloud the same way it works on Server.
Rogério Paiva [Xray Support Team]
Ami Panchal
October 28, 2021
Hi... Can you confirm if the Defect Default Values option is not available in Cloud instance or it is not working 100% correctly like it works on Server?
When I had trialed the X-ray cloud I remember seeing this option but now when I actually have cloud subscription I am not able to see Defect Default Values under X-ray miscellaneous settings.
November 9, 2021
Hi @Ami Panchal
By not working, I meant the feature does not exist in Cloud, so it does not have the option Defect Default Values.
Reed Martin
April 12, 2022
@Rogério Paiva - Xray Xporter Hello, do you know if this has changed or updated at all? Is there any other potential workaround? Thank you!
Rino Moen
Hey, I would actually like to remove this feature. Looks like these guys are trying to get it, but I have it and I cant get rid of it. Any other way to just stop it from populating the description field?
laralg
November 26, 2019
I think that you would need some kind of app to do this. If you are not familiar with programming I would try first with Automation for Jira, and if that is not enought then Scriptrunner.
good luck.
