need help to create a message on customer portal
Tushar Kamble December 6, 2017
Need help to show/display the issue/request created message on the customer portal after clicking submit button
Eg. The request has been created successfully with request#
H K
December 7, 2017
Hello @Tushar Kamble,
we are using an automation rule that adds a comment to the ticket. You can find this under project settings > automation.
E.g.:
WHEN "issue created"
IF "user type = customer"
THEN "Add comment"
Write your text and set the comment type to public.
Maybe this would be an adequate solution for you, too.
Learn more
